Battery Dies
DANIELGUY1965
  • 6 POSTS
I have a 1987 Honda Accord.
If I drive it a short distance, turn it off, and try to start it again the battery is dead.
If I drive it a long distance and leave it sit for hours it is fine.
It has a new alternator and a new battery.
The volts on the battery, while running, is over 13 volts. So it appears the alternator is working properly.
The car can sit over night and start fine in the morning, so there is no drain on the battery. But, if I drive it up the street to the store. Turn it off and try to start it again, the battery acts like it is dead. Once I put the jump box on it, it starts right up.
Jun 18, 2007 at 8:57 AM
MIKE H R
  • 3,094 POSTS
check the wires going to the battery from the altinator. The altinator could be putting out the 13 volts but it seems it is not charging the battery. With the car sitting the battery will recover somewhat just by sitting. With the car running disconnect the negative side of the battery. the car should keep on running, if not it is drawing voltage out of the batter to keep running. Have you noticed the headlights growing dimmer at night, or accessories not working normally?
Jun 18, 2007 at 9:43 AM
DANIELGUY1965
  • 6 POSTS
No I have not noticed any lights dimming.
I did replace both battery cables and it seemed to work for a short time. Then it started acting up again.
Jun 18, 2007 at 12:50 PM
MIKE H R
  • 3,094 POSTS
even with 13 volts at the battery. try disconnecting the negative side while the car is running. it seems like it is not charging or the voltage regulator inside the altinator is grounding out ht e charge. is there a store like auto zone near you? if not take it to a garage to check the amount of voltage going into the battery when the car is running.
Jun 18, 2007 at 2:26 PM
DANIELGUY1965
  • 6 POSTS
I did exactly what you said. I removed the negative cable while the car was running and it did not shut off.
Could it be the starter?
Jun 19, 2007 at 10:14 AM
MIKE H R
  • 3,094 POSTS
does it start all the time with a jump box? When you try to start it and it doen't can you hear a clicking sound comming from the starter solonoid? The starter could be the problem, it seems like it gets hot it does not want to crank over and when it cools then it starts. Re check the wires from the battery to the starter. what puzzles me is that you replaced the battery and cable and it worked all right for a while.
Jun 19, 2007 at 10:32 AM
DANIELGUY1965
  • 6 POSTS
Yes, it starts right up with the jump box. No problems at all. No clicking or anything. Just fires up.
When it does,the memory in the radio is gone and sometimes the clock is messed up.
Jun 19, 2007 at 12:20 PM
DANIELGUY1965
  • 6 POSTS
Any ideas?
I know I am at a loss.
Jun 21, 2007 at 2:10 AM
MIKE H R
  • 3,094 POSTS
check the fuses. the car is not charging. the radio memory will do that when the battery dies. Take it to a auto parts store like auto zone, they will be able to check the charging system and starting system.
Jun 25, 2007 at 9:13 AM
