Have the garage install leak detecter, it can be picked up at a auto store it will show blue if there is a leak, ac is under high pressure then you can see if you need to get another compressor. You can get one from a junk yard, if the compressor has pressure when you start to take it off then it should be good. Remember to match the compressor up to the one you are replacing
SPONSORED LINKS
Thursday, March 22nd, 2007 AT 8:38 AM
