1992 Honda Accord No Air from Vents
KRIS213
my ac on my 1992 honda accord is not turning on. there is no air coming out. what could be causing this?
Jul 12, 2007 at 8:20 AM
BRUCE HUNT
  • 3,754 POSTS
Must be related to the switch. Does the air blow with the A/C off and on vent or heat?
Jul 12, 2007 at 8:31 AM
KRIS213
[quote:a647319264="Bruce Hunt"]Must be related to the switch. Does the air blow with the A/C off and on vent or heat?[/quote:a647319264]
no, nothing happens when u turn the switch. when u push the AC button u can hear something like turn on, but no air comes out either way.
Jul 19, 2007 at 8:53 AM
BRUCE HUNT
  • 3,754 POSTS
Check the fuse to the fan. There might be a relay on the fan. If all else fails try wiring the fan direct to 12volts to see if it works.
Jul 19, 2007 at 9:48 AM
Suggested Repair
Check the blower fan fuse and any fan relay. If those are good, apply 12 volts directly to the fan to see whether the blower motor runs.
Conversation Summary
The owner of a 1992 Honda Accord reports that the A/C does not turn on and no air comes from the vents. Nothing happens when the fan switch is turned, although something can be heard when the A/C button is pressed. The expert suggests checking the fan fuse and possible fan relay, then testing the fan by wiring it directly to 12 volts.
