new plugs, cap, rotor ( 1 Month old ) Last week the car just started cutting out while driving, would crank back easy and then eventually do it again and progressively got worse until now it will idle smooth, but will not throttle up with out trying to stall and miss, and the check engine light has not on
when I try to drive it. I also cleaned the EGR valve with brake cleaner, checked main relay ( tested good ). That is where I'm at so far.
Thanks in advance for any help, Art
Saturday, September 29th, 2007 AT 11:00 PM
