Accord dies at stops
MADDLAGGER
Hi All,
Twice in the past week my 2001 4-cylinder Accord has died on me while slowing to a stop after 20 to 40 minutes of normal driving. I have been able to start the car back up immediately and continue driving as usual with no difference in performance or handling.
Aside from this, I have noticed that my car has sometimes dropped to sub-500 rpms while sitting at a stop a few minutes after starting.
What could be the cause of this?
Thank you for your help in advance
Nov 17, 2007 at 12:28 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0a22eaf265="maddLagger"]Hi All,
Thank you for your help in advance[/quote:0a22eaf265]
IAC
idle air control try cleaning it
when was the last tune up
good luck
Nov 17, 2007 at 2:29 PM
MADDLAGGER
[quote:2dc5a989b4="BMRFIXIT"][quote:2dc5a989b4="maddLagger"]Hi All,
Thank you for your help in advance[/quote:2dc5a989b4]
IAC
good luck[/quote:2dc5a989b4]
Thanks BMRFIXIT, I'll take a look at the IAC in the morning.
The last tune up was about 4 months ago now, spark plugs and wires were changed, air filter, pcv valve, an oil and oil filter change, and some fuel injector cleaner was mixed in with my gas. I think I'll also look into changing my distributor cap and fuel filter; I have close to 100k miles now.
Nov 17, 2007 at 9:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0266ad4591="maddLagger"][quote:0266ad4591="BMRFIXIT"][quote:0266ad4591="maddLagger"]Hi All,
Thank you for your help in advance[/quote:0266ad4591]
IAC
good luck[/quote:0266ad4591]
The last tune up was about 4 months ago now, spark plugs and wires were changed, air filter, pcv valve, an oil and oil filter change, and some fuel injector cleaner was mixed in with my gas. I think I'll also look into changing my distributor cap and fuel filter; I have close to 100k miles now.[/quote:0266ad4591]
All good but try to clean idle air control valve u may have carbon build up in it
Causing it to stick
Nov 18, 2007 at 12:29 AM
