1999 Honda Accord Accelerator Sticks
SSTRANGE
  • 5 POSTS
'99 Honda Accord, 89k miles. When I start driving, if I try to ease the accelerator as I start, it kinda sticks or hangs and then jumps, causing a quick acceleration. Suggestion?
Apr 10, 2006 at 11:06 PM
BRUCE HUNT
  • 3,754 POSTS
Check out your cable by unhooking it from the injector and having it free. How easy does the pedal move the cable. If not freely, either locate the sticking and lubricate or replace. Make sure that the injector throttle without the cable attached moves freely and smoothly. If it hangs or does not move smoothly either find where it is hanging or replace the throttle body.
Apr 13, 2006 at 3:28 PM
SSTRANGE
  • 5 POSTS
Thanks, I'll try that.
Apr 18, 2006 at 11:03 PM
Suggested Repair
Disconnect the throttle cable and check that the pedal moves it freely. If it binds, locate the sticking point and lubricate it, or replace the cable. With the cable off, confirm the throttle body moves smoothly; if it hangs, free the binding point or replace the throttle body.
Conversation Summary
The owner of a 1999 Honda Accord with 89,000 miles says the accelerator sticks or hangs, then jumps, when easing into it from a start. The expert recommends checking cable movement with the cable unhooked and lubricating or replacing it if it does not move freely, and checking that the throttle body moves smoothly without the cable, replacing it if it hangs. The owner said they would try that.
