98 honda accord ex-code p1382 & stalling at stops
ABBASCHILD2
4 cyl, mileage 150k. already chg'd plugs, wires, rotor, cap. tried replacing distributor. didn't help. what u thinki should try next? thanks for your help.
Susan
Mar 22, 2007 at 12:22 PM
BRUCE HUNT
  • 3,754 POSTS
Your code refers to an Acura vehicle but I would take it from the stalling and the code that it is possible that the crankshaft position sensor is failing. I suggest that you clear the codes and drive. When the light comes on again pull the code. Let us know what you find.
Oct 10, 2017 at 10:08 AM
ABBASCHILD2
[quote:63c210c4ad="Bruce Hunt"]Your code refers to an Acura vehicle but I would take it from the stalling and the code that it is possible that the crankshaft position sensor is failing. I suggest that you clear the codes and drive. When the light comes on again pull the code. Let us know what you find.[/quote:63c210c4ad]
the same code is still there after clearing and driving. i know how to use an ohm meter. can you tell me how to remove the timing belt cover to access the crankshaft position sensors? the manual i have isn't very helpful on that. thanks!
BRUCE HUNT
  • 3,754 POSTS
After you take off the external belts, you need to take off the harmonic balancer (the main pulley on the crankshaft). Can be a fun job removing that thing. Once that is off the rest is pretty straight forward.
