98 accord temp problems...PLEASE HELP
MATTMIC
I have a 98 accord ex v-6 with 149000 miles. I have owned the vehicle for 6 years, with no problems. Recently when the car is being driven during the heat of the daytime, the temp guage will go up and the a/c will stop blowing cool air. If I turn the a/c off the temp slowly goes back to the normal range. I do not have this problem when it is cool out. I decided to change and flush the coolant system as well as install a new thermostat. I did both of those things and the car is still doing the same thing. Can the a/c put that much strain on the engine to make it run hot? The car runs great if the air is off, i do seem to notice that the car is not as strong with the a/c on, it seems to loose some power, and i don't remember it being this way in the past. Any ideas I would really appreciate it!
Matt
Jul 1, 2006 at 5:59 AM
BIGJOE
:x I have similar problems with my 95 Accord EX 135K miles. During daytime hours if I have the A/C on high speeds the Temp gauge rises. I have to turn off the A/C till it cools down. I've had the water pump, thermostat, and cooling fan relay replaced but the problem is still present. I'm looking into the A/C condenser and radiator for problems.
Jul 19, 2006 at 7:13 AM
