'95 Accord V6 RPM Gauge going bonkers!!!
1995 HONDA ACCORD
CAROLANNLAND
This just started yesterday. For some reason the RPM gauge starts bouncing around like a ping pong ball. Note that my engine does not rev and is acting perfectly normal...sometimes the RPM Gauge catches to where it should be and will be fine for a while, but then will start dancing all over the place for no reason. Is this something that I should be deeply concerned about?
Mar 28, 2007 at 12:42 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
No it is not. If you are noting no other erratic behavior by the speedometer, the best bet would be the gauge itself. Buy a used cluster on the internet. You can get one pretty cheap and replace it. You can still buy a new one if you wish.
Mar 28, 2007 at 8:40 PM
