If you stop, turn off the car and let it cool off a long while, it usually is fine again, until you take corners again.
Symptoms: overheating, heater blows cold air, happens around corners, downhill. Overflowing coolant tank.
I have 2 guesses.
1. Junk in cooling syst. Is stirred up by cornering and plugs thermostat and heater inlet?
2. My water pump is shot, and car has been running on thermal updraft, but cornering moves hotter water towards the temp. Gauge?
Thank you so much for you help, I have my cooling system taken apart right now, and I need some advice.
SPONSORED LINKS
Saturday, June 16th, 2007 AT 5:13 PM
