One of my belt pullys squick when i first start my car as well as grey smoke from that pully. What should I do
Jan 23, 2007 at 2:01 AM
Confirm the drive belt is properly tensioned. If the alternator pulley still smokes, remove the belt and turn the alternator by hand. If it does not turn smoothly, the alternator bearing assembly is bad and the alternator should be replaced.
A 1994 Honda Accord LX squeaks and produces grey smoke from the alternator pulley at startup. The owner already replaced the belt and asked about a tensioner and the smoke. The expert advised verifying proper belt tension, then removing the belt and turning the alternator by hand. If the pulley does not turn smoothly, the alternator bearing assembly is bad rather than the electrical components.
