93 ACCORD HAS OIL ON BOTH SIDES OF PLUGS
CALEBANDMICHELLE
i pulled my plugs out , and they have oil on top of plgs covering the wires and also on bottom side of plugs. i thought this may be the valve colver gasket gone bad, but obviously i have a feeling its worse than that. please help
Jan 24, 2007 at 6:58 AM
BRUCE HUNT
  • 3,754 POSTS
I'll bet the plug was very well with oil, even the tip. Right? Did the car run? I suspect that it did. So, it is time for a valve cover gasket kit to be put in. Get the wires out of the way and take off the four cover nuts and remove the valve cover. Get the old gasket completely off both cover and head. You will see the holes for the plugs and the black gaskets for them. Those will be replaced as will the gaskets around the cover nuts. Put it all back together, use the proper torque on the nuts and everything should be fine.
Jan 24, 2007 at 8:04 AM
CALEBANDMICHELLE
so i got the gasket set, and yes it has the valve cover seal, grommet set, spark plug tube seals and 4 other o ring type things. i was wondering what those replace. theey are similar in size to the sparkplug holes. any ideas? its a felpro brand set. i included the factory picture so maybe that will help thanks for all your help
https://images.2carpros.com/forum/automotive_pictures/55629_valve_cover_seals_1.jpg
Jan 25, 2007 at 3:31 AM
BRUCE HUNT
  • 3,754 POSTS
The last orings that you are talking about will more than likely be for the injectors. That is your option to put them on and it surely won't hurt to do that.
Jan 25, 2007 at 8:02 AM
LOSTINMARS
  • 222 POSTS
[quote:0c6618aca2="Bruce Hunt"]The last orings that you are talking about will more than likely be for the injectors. That is your option to put them on and it surely won't hurt to do that.[/quote:0c6618aca2]
huh??? those are some pretty darn big injectors. injector o-rings do not come in a valve cover kit for any honda 4cyl i've seen.
Jan 26, 2007 at 9:07 PM
