1992 Honda Accord Weak Brakes
TRICKSHOT1126
While driving the car the break system seems as if its not working right. It takes a long time for the car to come to a complete stop. Its not squeeking or grinding, just when the break peddal is pressed it slows but when it gets to a low speed its like it stops breaking. It feels like the car is trying to push harder then the breaks are working. Can anyone tell me what this may be?
Sep 29, 2006 at 5:04 AM
BRUCE HUNT
  • 3,754 POSTS
I would start by looking at the brakes. The rear are most likely drums and they could be locked up. Does the emergency brake work good? If not, start with the rear brakes. Secondly, check the rotors in the front and see if they are very shiny and smooth. Look at the pads as they can become glazed over from excessive heat. Replace parts as necessary.
Oct 4, 2006 at 12:47 AM
Suggested Repair
Inspect the rear drum brakes for lockup and confirm the parking brake works. Check the front rotors for a shiny, smooth surface and the pads for glazing from heat, then replace worn or glazed parts as needed.
Conversation Summary
The owner of a 1992 Honda Accord reports long stopping distances and weak braking at low speed, without squealing or grinding. The expert advises starting with the rear drums, testing the parking brake, and checking the front rotors and pads for glazing before replacing parts as necessary.
