90 Honda Accord
NEC5809
Please help How do you check if distributor is getting power. which wire to test??
Apr 24, 2006 at 5:00 AM
BRUCE HUNT
  • 3,754 POSTS
That vehicle has an internal coil. If you take an old plug and hook it up to any of the four plug wires and crank the engine there should be spark to the plug. You have not supplied much information at all. Wrong, we need the info, but I am guessing that there will be no spark for you. If I am correct, you will need to replace the internal coil on that vehicle.
Apr 24, 2006 at 11:35 PM
