1989 Honda Accord Losing Coolant
JIMMYV333
  • 8 POSTS
89 accord lxi, auto, 140kmi. I am losing antifreez but no signs of leaking.After I filled it up, the top rad hose is hot ,the bottom hose is luke warm,temp gage is normal,lots of heat inside but there is no preasure when I take the rad cap off.
Any suggestions?
Thanks, Jim
Feb 22, 2007 at 3:26 AM
CHEVY22
  • 1,375 POSTS
hi jim, you may want to have a cooling system pressure test done , if this does not reveal anything have someone do a block test , this is very simple and easy ,what it does is check for exhaust gasses in the coolant meaning a failed head gasket , but try the pressure test first
Feb 22, 2007 at 5:42 AM
JIMMYV333
  • 8 POSTS
what causes a cooling system to lose preasure?
Jim
Feb 22, 2007 at 6:25 AM
CHEVY22
  • 1,375 POSTS
its a closed system , so if there is a leak it will lose pressure from that point and just get worse with time
Feb 22, 2007 at 6:28 AM
Suggested Repair
Have the cooling system pressure-tested first. If no external leak is found, perform a block test to check for exhaust gases in the coolant, which can indicate a failed head gasket.
Conversation Summary
The owner of a 1989 Honda Accord LXi with 140,000 miles reports losing antifreeze without visible leaks. After refilling, the upper radiator hose is hot, the lower hose is lukewarm, the temperature gauge is normal, and the heater works, but there is no pressure when the radiator cap is removed. The expert explains that a closed cooling system loses pressure through a leak and recommends a pressure test first, followed by a block test for exhaust gases in the coolant if needed.
