1989 Honda Accord Headlight Coolant Leak
ZARZILLA
i recently received a 89 honda accord with 200000 miles took it to get emissions. under the passenger headlight it started to leak water or coolant i was wondering if this could be from the reservoir or something else. also the car runs hot when idle but when moving there are no problems. i was told to replace the thermostat and then if that does not fix the problem move to the water pump what is the best plan of attack?
Jun 1, 2007 at 3:35 AM
SQM
  • 6,383 POSTS
The first step should be to figure out where the leak is coming from. It could be the radiator hose or the radiator itself. Unless this gets fixed it could be difficult to pin down the overheating issue. As you know the engine can overheat due to being low on coolant.
Here is a helpful guide:
https://www.2carpros.com/articles/car-is-leaking-coolant
If the leak is difficult to see, you might want to do a pressure test on the cooling system, which can help with finding the leak.
https://www.2carpros.com/articles/radiator-pressure-test
If you still have the overheating issue after the leak fix, then from what you are describing it could be an inoperative cooling fan. If the fan is not working then there is no air flow thru the radiator, while the vehicle is stationary. This makes the engine overheat. But cools back down as you drive and have air flow through the radiator.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Oct 26, 2021 at 12:20 PM
Suggested Repair
Locate the coolant leak first, checking the radiator, hoses, and reservoir area, and pressure-test the cooling system if the source is hard to see. Repair the leak before diagnosing overheating. If the engine still runs hot only at idle, check the electric cooling fan.
Conversation Summary
The owner of a 1989 Honda Accord reported coolant or water leaking under the passenger headlight and overheating at idle but not while driving. They had been advised elsewhere to replace the thermostat and then the water pump. The expert recommended finding and fixing the leak first, using a pressure test if needed, because low coolant can cause overheating. If the problem remains, an inoperative cooling fan is a likely cause because airflow is missing at idle but present while moving.
