2008 Honda Accord Idles rough at stops
17,000 MILES • 6 CYL • FWD • AUTOMATIC
B. NELSON
How to fix rough idle at stops
Mar 23, 2010 at 11:06 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Mar 23, 2010 at 2:31 PM
