2008 Honda Accord heisitating while driving
57,302 MILES • 6 CYL • 4WD • AUTOMATIC
SAMIYASHILLEH
my car hesistates while driving from 20-to 40 mph i jsut got the erg valve replaced and cleaned all the ducts and still doing it what can it be??
Sep 3, 2010 at 5:15 AM
  • 75,988 POSTS
Possible causes:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 3, 2010 at 5:51 AM
