2008 Honda Accord gear problem
2008 HONDA ACCORD
ADE
Transmission problem
2008 Honda Accord 4 cyl Two Wheel Drive Automatic
the gear selection indication light for drive(D)IS CONSTANTLY ON and blinking , and i also notice the car does not exceed 80km at/hr at speed , the entire engine also vibrate sharply soon as u engage the drive
Apr 2, 2009 at 6:50 PM
KHLOW2008
  • 41,814 POSTS
Hi ade,
The PCM has detected a fault in the transmission system and you need a scan to find the cause of the blinking light.
Since vehicle is still under warranty, you should get back to the dealer to have a look.
Apr 8, 2009 at 1:56 AM
KARENCAREN
  • 72 POSTS
Get it scan dude. You will know what code is the problem. If you are still under warranty better go to your dealer. But if not, go to a good mechanic that have a scanner in his shop.
Apr 15, 2009 at 11:29 AM
