2007 Honda Accord power window problem
59,000 MILES • 4 CYL • FWD • AUTOMATIC
J_CAMPANELLA
Only the driver side window works. It's not locked but none of the other Windows work. I have checked the fuses and master relay. All are ok. The other Windows just make a slight clicking noise when depressed. Also when the lights are one only the driver & front passenger window switches illuminate
Jan 20, 2010 at 11:39 PM
GILBERTP
[quote:368b9c71b7="j_campanella"]Electrical problem
2007 Honda Accord 4 cyl Front Wheel Drive Automatic 59,000 miles
Only the driver side window works. It's not locked but none of the other Windows work. I have checked the fuses and master relay. All are ok. The other Windows just make a slight clicking noise when depressed. Also when the lights are one only the driver & front passenger window switches illuminate[/quote:368b9c71b7]
Your window master swith located on the door needs to be replaced if you have the four door it is P/N 35750-SDA-A14 around $140.00 and you will have to reprogram the security system, that I don't know how to do yet!
Jan 30, 2010 at 5:15 AM
