2007 Honda Accord power window problem
J_CAMPANELLA
  • 2007 HONDA ACCORD
  • 4 CYL
  • FWD
  • 59,000 MILES
Only the driver side window works. It's not locked but none of the other Windows work. I have checked the fuses and master relay. All are ok. The other Windows just make a slight clicking noise when depressed. Also when the lights are one only the driver & front passenger window switches illuminate
Thursday, January 21st, 2010 AT 7:39 AM
GILBERTP
Your window master swith located on the door needs to be replaced if you have the four door it is P/N 35750-SDA-A14 around $140.00 and you will have to reprogram the security system, that I don't know how to do yet!
Saturday, January 30th, 2010 AT 1:15 PM
