rear brakes really do not understand how to do the job
22,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALYOSH
Really do not understand how to do the job can you help?
Mar 2, 2009 at 1:46 PM
SEVAG P
  • 405 POSTS
hello,
Check our link below how to replace brake pads and rotors
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Check the diagrams below how to remove and reinstall brakes with the inspections, check how to measure the rotors lateral run out by using dial indicator, and rotors thickness by using micrometer and compare with the specification tables.
let us know if you need more help thank you.
Apr 9, 2021 at 4:32 AM
