beeping sound?
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
YASSERHB
How the stop the beeping sound that starts after crossing 120 km/h
Jun 13, 2008 at 10:23 PM
KHLOW2008
  • 41,812 POSTS
Hi yasserhb,
Is it legal for your vehicle to operate without this speed warning?
Jun 14, 2008 at 2:59 AM
YASSERHB
yes it's ok here people do it here all the time
Jun 16, 2008 at 2:33 AM
YASSERHB
yes it's ok, people here are doing it all the time
Jun 16, 2008 at 2:34 AM
KHLOW2008
  • 41,812 POSTS
Hi yasserhb,
For older versions the buzzer is located behind the meter assy but I do not know if there is any changes to the design or location for the newer models.
The only way to disable it is to disconnect it.
Jun 17, 2008 at 1:47 AM
APZ
I have a Honda Accord 1.8 SE, 2000 Registration, Manual and 60k miles on the clock.
When driving for about half an hour or so, i get intermittent beeps from the car. It seems to be coming from the front centre of the car. I get exactly 10 beeps and it stops. The behaviour occurs very randomly during the course of driving.
please suggest.
thank you very much and regards,
Aug 25, 2020 at 10:51 AM (Merged)
BRUCE HUNT
  • 3,754 POSTS
Does that car have the climate control or thermostatically controlled heating/air conditioning system?
APZ
No, it doesn't have climate control or any automatic temperature regulator..i checked the manual and it is just the normal AC in the car which is manually adjusted.
thanks!
BRUCE HUNT
  • 3,754 POSTS
The beeping is coming from the dash area or from under the hood? This car has the alarm system and do you still have the original radio installed? Does a check engine light come on or has it ever? Is it possible this is seat belt related?
APZ
The beep seems to be coming from the dash area. I cannot exactly spot if it is radio side or speedometer side, but seems like the speedometer side. I also got my local garage to check if all the warning lights are working and it is confirmed that they are.
I have the original radio installed. On more than one occasion i disconnected (took the front panel off) the radio to see if that makes a difference but it didn't.
No warning lights (check engine) comes up and it hasn't come up even once to the best of my knowledge.
I don't think it is seat-belt related. If there are two people in the car with the seat-belt fastened the beep still comes up.
I really appreciate your help, thank you very much!
Hope the information helps!
