2007 Honda Accord 2007 Honda Accord Badly Trembling
59,987 MILES • 4 CYL • FWD • AUTOMATIC
OCMP
I have honda accord 2007 automatic. After I changed transmission oil, when gear is shifting about 1,800 to 1,900 rpm, car is badly trembling.
The shop that I changed the transmission oil, that's common. Why does this happen? The clutch of transmission is bad? Do I need to fix the transmission?
Aug 14, 2009 at 2:29 PM
KHLOW2008
  • 41,812 POSTS
Hi ocmp,
Was the recommended trans fluid used?
Did the problem occur before replacement of the fluids?
Aug 19, 2009 at 2:09 AM
OCMP
Yes, it was happened before changing fluid.
Right now I am 60,000 miles over...
I never buy HONDA again.
Aug 19, 2009 at 8:06 AM
KHLOW2008
  • 41,812 POSTS
If the vehicle had been serviced regularly at the dealers, you can talk to them about a warranty or goodwil repairs.
Aug 20, 2009 at 3:06 AM
OCMP
Unfortunately,,,
I have no time to go dealer for busy work, it's over the warranty mileage 60,000. Right now it's 60,678 miles. Is it possible to get warranty in full cover? I feel very bad for HONDA ACCORD. I never buy & recommend HONDA again. HONDA's sucks & jerks.
Aug 23, 2009 at 5:21 AM
KHLOW2008
  • 41,812 POSTS
For transmisson there are extended waranty periods and you can check out with the dealer.
Did you confirm that the problem is from the transmission?
Was the shop that did the fluid change a cetrified Honda dealer?
Without getting to the bottom of the cause and giving Honda dealers a chance, you are not being fair to say that they are bad.
If you are busy and not able to send the vehicle to Honda you can't put the blame on them.
Call them and enquire about the warranty and make an apointment to have a test done on vehicle to verify the problem.
Aug 23, 2009 at 10:55 AM
