2006 Honda Accord starting
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
IRV62
once in awhile i turn the ignition on and nothing happens, i try it a few more times and it starts. i replaced the battery but problem still exits
Dec 17, 2009 at 12:04 AM
  • 110,244 POSTS
A few things can cause this. I need you to check something for me. When it happens, have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. It should have 12+ volts when the key is in the start position.
Let me know what you find and thanks for using 2carpros.com.
Dec 17, 2009 at 9:28 AM
