2006 Honda Accord Rotor rust
50,000 MILES • 4 CYL • FWD • AUTOMATIC
SSFACE
Hi..I am storing my Accord outside to 7 months. The brake rotors have started to rust. How can I prevent rotor rusr? thxx
Jun 2, 2008 at 12:44 AM
KHLOW2008
  • 41,812 POSTS
Hi ssface,
There is a certain kind of wax that can be sprayed to prevent the rust but spraying it is the problem. Without removing the rotors you cannot cover all the surfaces.
If you remove them to spray, might as well keep them indoors.
Jun 2, 2008 at 2:44 AM
SSFACE
Will a silicone spray work OK...or will that mess up the pads...??
Also, the WD40 suggests this is a use for their product??
thx
[quote:94720b45ff="ssface"]Brakes problem
2006 Honda Accord 4 cyl Front Wheel Drive Automatic 50,000 miles
Hi..I am storing my Accord outside to 7 months. The brake rotors have started to rust. How can I prevent rotor rusr? thxx[/quote:94720b45ff]
Jun 2, 2008 at 4:32 AM
KHLOW2008
  • 41,812 POSTS
Hi ssface,
Both type of spray won't last for 7 months. I believe WD40 is oil based so is not recommended.
Lacquer would be a better choice and they can wear off once you start using the car again.
Jun 2, 2008 at 6:57 AM
