2006 Honda Accord Power Steering Flush & refill
2006 HONDA ACCORD
62,500 MILES • 4 CYL • FWD • MANUAL
PAT PHELAN
Looking for some guidance on where to drain fluid.
Sep 3, 2010 at 2:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to drain power steering fluid you disconnect the return hose from the resevoir. to keep a clean area, you can attach a loose piece of hosing to the disconnected return hose and then run the hose to a suitable container to catch the fluid easier. when draining fluid, be sure to start engine and let it run at idle, turn the steering wheel from lock-to-lock several times until the fluid stops runnig out. always use NEW power steering fluid.
Sep 3, 2010 at 7:51 AM
