2006 Honda Accord pLEASE HELP
70,000 MILES • 4 CYL • FWD • AUTOMATIC
SARTAJALAM
I have problem with my car. Hope I will get help from to solve my problem. Its engine vibrates and increase vibration when switch on AC. I had changed all mountings, plugs and cleaned fuel injector but no result.
Jun 2, 2010 at 7:59 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Is Check or Service Engine Light on? If so would help if could go by your local parts store and have them pull codes. Write them down and post here in forum.
Some causes are Vacuum Leaks, Bad Plugs (which you stated you changed) Next would be Coils or the Plug boots. And then the Motor and Tranny Mounts and I believe you said you changed those.
Jun 3, 2010 at 12:42 AM
