2006 Honda Accord NEED HELP!!!
105,000 MILES • 4 CYL • 2WD • MANUAL
ELVIS25
I bought 2006 honda accord with broken radiator.I change the radiotor and now when I'm trying to drive I put first shift...It's starting and then nothing... just stop .Before was running great even with broken radiator. Maybe I broke some sensor ??I don't know what's wrong . Please answer !!!Thanks
May 7, 2010 at 8:56 AM
KHLOW2008
  • 41,812 POSTS
Hi Elvis25,
Thank you for the donation.
Do you mean the engine is starting and stalling or yu are not able to move in gears?
Is the Check Engine Light staying on after starting?
May 7, 2010 at 9:59 AM
ELVIS25
check engine is staying after i start the engine, and the car is starts and goes without no prblem and then the transsmission is sleeping the car doesn't go , like the dears is not working
May 7, 2010 at 2:31 PM
KHLOW2008
  • 41,812 POSTS
The CEL staying on while the engine is running indicates an error has been detected and trouble codes are stored in the PCM.
Get a free scan done at Autozone and let me know the exact code so we can understand the problem better to proceed with diagnosis and rectification.
May 8, 2010 at 5:36 AM
