2005 Honda Accord When AC on radiator fan comes on too ofte
108,180 MILES • 6 CYL • FWD • AUTOMATIC
LIDA1111
When the vehicle is idleing with the air conditioner on, the radiator fans come on too frequently. This also happens when the car is cold and it is below zero outside. When the vehicle accelerates with both fans running a lound whining noise is heard. Sounds like the fans are over reving the engine rpm. Have replaced the condensor.
Jun 2, 2009 at 2:30 PM
KHLOW2008
  • 41,812 POSTS
Hi lida1111,
When the AC compressor is running, the fans must be working.
If the noise you are experiencing is a squesling type noise, check th AC belt condition and tension.
Jun 5, 2009 at 9:06 PM
