Power Steering Whine
94,000 MILES • 6 CYL • FWD • MANUAL
KILLERDC
Now that it has turned colder, 50 degrees or so, my car makes an awful noise when I turn it on in the morning. I believe it is linked to the power steering somehow. It makes the noise regardless of whether I am turning the wheel or not, but when I turn the wheel, it makes an even louder noise. After I let the car warm up for about 10-15 minutes and the engine gets up to operating temperature, the sound goes away, and as long as the temperature stays over 50 degrees it does not come back. Since I live 20-30 minutes from the dealer, there was no way for me to re-produce the sounds for them, because the sound was always gone by the time I could get there. So I took my high tech camera and video'd the problem in high definition and took it to them, but they refused to help. They said the only thing they could do is for me to leave it overnight and they would look at it in the morning. Well that is nearly impossible for me to do given I have to take kids to school etc. The shop foreman who looked at it, said best guess was that it was the power steering pump, and it would need to be replaced. Total price is nearly 700 dollars. I am not at all car inclined, but am very mechanically inclined, so if I can figure out what is wrong, I will attempt to do the repair myself.
I saw a previous post on here mentioning something about just replacing the O-ring. I'm not sure that this is the same issue. The fluids are fine, just had oil changed 2 days ago and was told all fluid levels are topped off.
Dec 4, 2009 at 1:34 PM
STEALTH916
  • 5 POSTS
I also have an Accord V6 EX, 2005, with 84K miles on it. I am just now experiencing this problem. When it is very cold in the morning, I am getting a loud whine coming from the power steering pump. After 5 minutes or so it goes away as the temperatures come up.
I do not see any leaking fluid, kinked hoses etc. Fluid level is normal. I have a 6yr/100,000mi warranty which will hopefully cover this if it is a major repair.
Dec 5, 2009 at 12:16 PM
STEALTH916
  • 5 POSTS
I just found this service guide that helped me fix the problem.
https://www.2carpros.com/articles/power-steering-fluid-flush
I flushed the fluid and the noise is gone! I love this site.
Dec 5, 2009 at 12:21 PM
STEALTH916
  • 5 POSTS
I also did observe foaming in the power steering fluid reservoir when the system was cold and making the 'whine' noise.
So I purchased the new O-Ring from the dealer (total cost 68 cents).
I installed the part in less than 10 minutes. The only tool required was a standard 10mm boxed end wrench with a standard offset. You only have to remove one bolt. Very little fluid came out of the inlet hose when it was removed, but be sure to have a rag underneath the inlet.
Remove the old O-ring, which will probably be in the pump housing, lube the new O-ring with power steering fluid and install the new O-ring over the inlet hose assembly, and reinstalll the inlet hose. Install the bolt and tighten but do not overtighten. Use a torque wrench set to 8 ft lbs if you have it. Start the car and observe for any leaks.
I should know tomorrow morning if my problem has been fixed, as we are expecting temperatures in the mid 20's overnight.
Dec 8, 2009 at 2:40 PM
KILLERDC
I am interested in finding out if this worked?! I am planning on going by the dealer today to pick up that part, and will replace it tonight, if they wont do a courtesy repair.
Dec 9, 2009 at 12:50 AM
STEALTH916
  • 5 POSTS
Yes, it seems the O-Ring did fix my problem. It was very cold again this morning, but the power steering pump never complained and the fluid did not foam. I never heard even a hint of the whine/moan sound. I could tell as soon as I started the car that the problem was resolved...
Best of luck!
Dec 9, 2009 at 3:22 AM
KILLERDC
Thanks for the info.
Im gonna call up the dealer and see if they will do a quick courtest repair, and if not, I will just run up there and buy the part and do it myself.
Dec 9, 2009 at 3:25 AM
KILLERDC
91Cents. That was the cost after tax of a new O-ring. Took me more time to find the proper wrench then it did to replace the part, and saved me 698.00, which is what I was told it would cost to fix the problem. That was the cost of a new power steering pump, and etc....
Thanks for the info. With xmas right around the corner, saving 700 bucks is huge. My kiddo's wont have to cut back quite so much. :)
Thanks again, and I will use this service whenever I have any issues.
Dec 9, 2009 at 11:44 PM
2012CHUCK
I had the same problem with my 2005 accord with 95000 miles. The dealer fixed it with a one dollar o ring. No charge for labor.
Dec 7, 2010 at 10:42 AM
STEALTH916
  • 5 POSTS
I wanted to follow up since it has been a year that I did this repair. The repair is still working fine and I have had no further problems with the power steering pump on my Accord.
2 weeks ago, my 2006 Honda Odyssey also started giving me similar trouble, although it did it only when the car was WARMED UP (?). I visually verified foaming in the fluid reservoir, then went to the dealer and picked up another $1 O-ring. It was harder to access the bolt on the Odyssey, but I was able to just barely manage it using the same small 10mm box end wrench. It seems that the new O-ring also solved the problem in my Odyssey.
Dec 7, 2010 at 10:52 AM
HPEREIRA0893
Thank You for this very helpful information. I have had this issue on going for the past three years. I have taken my car to many mechanics and also to the HONDA dealer, interestingly enough no one could diagnose the foam in the reservoir, loud noise and the wet hoses. The noise is now louder than ever and even on our warm mornings it's loud. THANK YOU AGAIN .....
Jun 13, 2015 at 7:20 AM
VGRONKOWSKI
I drive a 2004 Honda Accord EX. For the past year, I have noticed that when it is colder outside, my car makes a loud squealing noise especially when I turn the wheel. I took my car in to replace the serpentine belt, and was told I needed to get my rack and pinion replaced for $1100. I had someone take a look at my car who was a car mechanic in the past and said my rack and pinion was dry. He did notice a small leak around the bottom hose that connects to the power steering pump. I read on here that an O-ring needs to be replaced on the power steering pump inlet joint. Is there anything else that should be replaced?
Jan 7, 2019 at 3:10 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
If you're replacing a hose, it will come with new O-rings. None of these things are going to cause a squealing noise unless this oil is getting on the belt
VGRONKOWSKI
If there's a leak, can't air get into the system to cause that noise? Noise is gone once it has warmed up.
WRENCHTECH
  • 20,760 POSTS
Air noise is growling, belt noise is squealing.
VGRONKOWSKI
well, belt was replaced, noise remains. Let's call it growling then! Would it be an replacement of the hose(s) and O-rings?
HONDA TECH 1818
  • 536 POSTS
Air is entering the pump through the o-ring. Replaced the powersteering pump inlet joint o-ring and that would fix it.
ENATION
I have a Honda accord v6. when the car is cold the power steering pumps makes a loud noise. as soon as the car is wormed up it will go away.how do i determine what it is exactly.
ERNEST CLARK
  • 1,730 POSTS
First check your fluid level. Don't overfill it. Then check the conditions of your belt. If it's loose or worn, replace it.
When the pumps begin to go bad, they begin to make a whining noise. To confirm it's the pump, remove the belt and turn each pulley by hand. If one/more has any resistance or make noises, replace them.
VGRONKOWSKI
Thank you. I will do that. How much do they typically charge to replace the o-ring?
DRCRANKNWRENCH
  • 3,380 POSTS
It is either the belt slipping, low fluid level or the pump is failing. If the belt is loose, you can check the slack by pushing on it. it should not move more than a cm or so. The entire range can be mesures by pushing it in and pulling it which whould be, about 1/2 inch for a V type belt or 1/4 inch for a flat belt.
Check the level when the vehcicle has been driven around some. Also check if the fluid looks burnt or dirty.
A few questions;
Have you ever used power steering fluid that did not have, "For Use In Hondas" on the label?
Does the noise change when turning the wheel lock to lcok at a standstill?
Let em knwo and I wil reply ASAP.
HONDA TECH 1818
  • 536 POSTS
The o ring is about 2-5 dollars at the dealer. You will need a bottle of Honda powersteering fluid also. You can do it yourself it's not hard at all. All you need to do is found the powersteering pump and remove the 10mm bolt and the black inlet joint at the front of the pump and replace the o ring. (when you remove the inlet joint use a cloth to catch some of the fluid)
ADH601
I have a 2004 Honda Accord with the 6 cyl. The power steering pump makes a lot of noise when cold, but the pump still works fine. After inspecting the pump I found no leaks and the fluid level is at full. I did notice that the hose comming from the top of the pump has some oily build up at one of the connection joints. My thouhgt is that there is small leak that allows air into the system. Once the engine warms up and the pressure builds the air is removed and the noise goes away. Should I replace this hose? Can this hose be repaired?
F4I_GUY
  • 3,302 POSTS
[quote:ccd8b11de9="adh601"]Steering problem
2004 Honda Accord 6 cyl Front Wheel Drive Automatic 61000 miles
I have a 2004 Honda Accord with the 6 cyl. The power steering pump makes a lot of noise when cold, but the pump still works fine. After inspecting the pump I found no leaks and the fluid level is at full. I did notice that the hose comming from the top of the pump has some oily build up at one of the connection joints. My thouhgt is that there is small leak that allows air into the system. Once the engine warms up and the pressure builds the air is removed and the noise goes away. Should I replace this hose? Can this hose be repaired?[/quote:ccd8b11de9]
Sounds like your low pressure hose, if so then yes it can be replaced. If you see oily residue on it, it may have a very small leak. I would definately replace it and bleed the steering system of any remaining air afterwards.
DABLCKPRL
The problem is a very simple to fix. The O-Ring that connects one hose to the P/S is bad, it has to be replace. The Honda part number is P/N 91345-RDA-A01 ...
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
The above link is a guide to help u change it.. it takes like 2minutes and u are set...
The problem as stated above is a leak, air is coming in by the O-ring not doing its proper job. Overall you need the O-ring, which runs about $1.5 from Honda dealerships and Honda P/S fluid, about $3 for a bottle.
This is a $4 job not a $150+ as most dealerships charge.
Jan 7, 2019 at 3:11 AM (Merged)
ALZALLC
  • 5 POSTS
Looks like I have the same problem. I replaced the O-ring recommended by dablckprl but it didn't help. There is a leak in the pressure hose comming from the top of the power steering pump. The lower hose is a return hose only.
Looks like I need to replace the p/s pressure hose which is a lot more complicated? Do you think that I should also replace the pump itself?
DTHOMA
Thanks dablckprl for the link to the service bulletin. I have a 2005 V6 Accord 105k miles with the same noise problem when I first start my car in the mornings and was able to fix it by replacing the O-ring.
TRIPNOTIZED
I live in Brooklyn, NY and I need the O ring replaced on the steering pump in my accord. I have the O ring, just don't have the tool to replace it. If anyone wants to do it for me let me know, we will agree on the price.
CARIJEREMY2
I took it to different mechanics. 1 said it was a simple o-ring, the other said the whole pump as they cannot order separate parts. The car wines when cold but stops after it is warm. there is fluid on the reservore and needed to be filled. I dont know what to do
  • 110,248 POSTS
Does the noise go away when the PS fluid is full?
SATURNTECH9
  • 30,869 POSTS
So where is it leaking?Are you sure the rack and pion isnt leaking into the rack boots?
CARIJEREMY2
We added more fluid. We are going to change the o ring outside the pump first to see if that helps
