Will there be any damage to the car if I contiue to drive it? Estimated cost to repair? Time frame to repair?
Nov 5, 2010 at 11:52 PM
KHLOW2008
✓Experienced Mechanic
Hi shw5655,
Which O ring are you referring to?
It is ok to drive the car as long as the power steering is working and fluid level is not below minimum. If the fluids run dry, you are going to cause damage to the pump might result in heavy steering.
