2005 Honda Accord Overheating
66,000 MILES • 4 CYL • FWD • AUTOMATIC
BRANDI562
I have an 2005 Honda Accord and the other day my Husband and I noticed the heat was not working correctly until we were driving then the care would heat up. We got and couple of miles down the road and noticed the car overheating and pulled over to the side and lefted the hood to discover a black hose with clear fuild coming out of it. Can you please advise me to what might cause this and is the a costly repair. Also we can not run the heat nor drive fast or the car will overheat.
Thank you
Oct 26, 2008 at 6:05 AM
KHLOW2008
  • 41,812 POSTS
Hi brandi562,
When overheating occurs, you need to check the radiator coolant level. Most probably there is not enough.
You need to check for leakages and the hose you mentioned, is the fluid oil or water based?
Oct 27, 2008 at 6:18 AM
BRANDI562
Thank you for your response. I took it to the shop and infact it was a valve the was cracking and needed to be replaced. I needed my heat it is getting COLD here int he Washington, DC area......AGIN THANK YOU
Oct 28, 2008 at 6:09 AM
KHLOW2008
  • 41,812 POSTS
Hi brandi562,
You are welcomed.
I am glad that you have solved your problem.
Oct 28, 2008 at 9:20 AM
