2005 Honda Accord noise in power pump
200,000 MILES • 4 CYL • FWD • AUTOMATIC
MALIK81
hi,
there up normal sound comming from enging i checked i assum sound is comming from power pump.
also i have another problem air bag indication always lighting at same door remote control problem is comming. i don't is there any relation
Jun 14, 2008 at 11:24 PM
KHLOW2008
  • 41,812 POSTS
Hi malik81,
If the power steering pump has a whirring noise, most probably you have to replace it. The front or rear end bearing in the pump is faulty.
If the SRS indicator light illuminates, you need to scan for the code to know what is wrong.
Remote door control, sorry I don't understand your question. Is it the door open indicator light is showing?
Jun 15, 2008 at 12:31 AM
