2005 Honda Accord Gear Shift light doesn't work
107,000 MILES • 4 CYL • FWD • AUTOMATIC
JONETTE
THe light on the gear shift went out. Trying to check the fuses but don't see one listed for gear shift light. Checked both under the hood fues and interior panel. Can you tell me which fuse it would be. All other lights seems to be working fine.
Oct 11, 2009 at 2:30 AM
KHLOW2008
  • 41,812 POSTS
Hi Jonette,
The gear shift illumination lights are in parallel with the taillights and dash illuminations. The most likely problem would be the bulb is fused. You would have to remove the console to replace the bulb.
Oct 15, 2009 at 4:55 AM
