Changing Air Filter?
70,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHMUGGS
Sounds simple but in the 2005 Accord, I can undo the 4 screws simply enough, but can't seem to lift the cover off, as it bumps into the front left side of the car.
Any tricks I need to know?
Jul 5, 2008 at 2:11 AM
The trick to this is to remove the hose from the air box first and then you can remove the screws and the top will come off easier.
Here is a guide that will help with this as well:
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
Lastly, I attached the info below from the manual that will help as well. Let us know what other questions you have. Thanks
Jan 29, 2021 at 10:46 AM
