2005 Honda Accord Air conditioning problem
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICHOLE761
I have a 2005 Honda Accord. I have a dual AC controlled both on passenger and driver side. The passenger side vents work and blow cold while the Driver side blows hot. I had the clutch replaced because it blew due to the pressure built up in the compressor after taking it out of the shop it worked for twenty mintues then stopped working. Please help No one seems to know why its not working.
Jul 21, 2008 at 9:40 AM
KHLOW2008
  • 41,812 POSTS
Hi Nichole761,
The compressor is not working? Are both the fans working when AC is turned on?
Blower, is it working?
If the air mix is not working properly, you need to find out if there is any DTCs.
Jul 22, 2008 at 8:33 PM
