2005 Honda Accord AC Blowing Hot Air
53,000 MILES • 6 CYL • FWD • AUTOMATIC
USAFGARRETT
My climate controlled ac is blowing hot air. I checked the refrigerant level and it says its at 90 psi, this is with the engine hot. When I turn on the AC the fan kicks on for about 2-3 seconds and then turns off. It does this intermittently as long as I have the car on. Is there a clog or what?
Mar 25, 2008 at 11:21 AM
DNKRZ125
i have an 05 accord 43k just did the same problem, RIGHT AFTER i added 1 can of freon. It seems like these car have a limit on the amount of freon u added, and if u pass the limit the ac isnt going to work properly. Alot of the pressure systems that the local stores have to measure the Ac systems arent accurate and u probably wont get an accurate result. After driving a while my ac is working again.. it seems like i gotta let some of the freon get wasted. Did u just add Freon ?
May 11, 2008 at 9:21 AM
