2005 Honda Accord
CMD82242
Engine Performance problem
2005 Honda Accord 6 cyl Automatic 90,000 miles
My car all of a sudden appears as though it's in Neutral or stuck between gears. It's an automatic transmission, and this occurs while it's in drive. I can see the RPM's increasing as if the car is accelerating, but it's not. It got to the point where even when pressing on the gas it just wouldn't move. We turned the car off and then on again and I was abe to drive a short distance before it basically slowed to a stop again. What could this problem be?
Jun 27, 2010 at 10:23 AM
KHLOW2008
  • 41,812 POSTS
Hi CMD82242,
Symptoms indicates a failing transmission. Get a free scan done at Autozone to retrieve for trouble codes and let me know the exact truble code if any found.
Did you check the transmission fluid level?
Jun 30, 2010 at 5:43 AM
