2004 Honda Accord VIBRATION
102,000 MILES • 4 CYL • FWD • MANUAL
RWADE
I RECENTLY GOT NEW TIRES ON THE CAR AND SHORTLY AFTER DEVELOPED A VIBRATION, IM NOT SURE IF IT IS THE TIRES BECAUSE IT ONLY VIBRATES FROM ABOUT 55-65MPH ONLY UNDER ACCELERATION, THERE IS NO VIBRATION WHILE COASTING OR DECELERATING THROUGH THESE SPEEDS. THE CAR IS A FIVE SPEED AND THE LOWER THE GEAR I AM IN AND THE HARDER I ACCELERATE WORSENS THE VIBRATION, WOT IN THIRD GEAR IS VERY SHAKEY, WOT IN FIFTH GEAR IS BARELY NOTICEABLE, I HAD THE TIRES REBALANCED AND NOT SURE WHAT TO DO NEXT
Jan 17, 2008 at 8:54 AM
MASTERTECHTIM
  • 4,750 POSTS
you need to have every part in front end checked. ball joints, tie rods and cv joints. i bet you ll find the problem there. hope this helps
Jan 17, 2008 at 8:57 AM
MASTERTECHTIM
  • 4,750 POSTS
also check your engine mounts and your transmission mounts, if they are bad it will throw off the angle of your axle shafts causing vibration. feedback and votes are greatly appreciated
Jan 17, 2008 at 8:58 AM
