2004 Honda Accord PO499
OZZY60W
  • 2004 HONDA ACCORD
  • 4 CYL
  • 60,000 MILES
ENLGINE LIGHT KEEP COME ON SAY PO499 EVAP CANSTER VENT VALVE MALFUNC TAKE OUT CANTSER TEST VALVE WORK FINE CHACK HARNESS TEST 12V BULB LIGHT VERY LOW, GROUND TO BODY LIGHT NORMA
Saturday, October 30th, 2010 AT 3:20 PM
F4I_GUY
  • 3,302 POSTS
If you have power and ground to the vent valve when it is commanded "on" then you have a faulty vent valve.
Saturday, October 30th, 2010 AT 4:35 PM
OZZY60W
I switch car on vent valve not working use a jumper to body works, but code po498 curite malfunc. Is my compture is not sending seginal to vent valve because I am not getting 12v I get very low volt, does this mean my compture defective
Saturday, October 30th, 2010 AT 5:45 PM
HONDA TECH 1818
  • 536 POSTS
Check for a poor connection of the LT
GRN/RED wire on connector C501 at the left side of the dash between the PCM and the EVAP canister vent shut valve.
Monday, November 1st, 2010 AT 2:04 AM
