Key stuck in ignition
2004 HONDA ACCORD
66,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIM BROPHY
I have a 2004 Honda Accord and the keys are getting stuck in the ignition. If I restart the car and push the gear shift forward with addition force the key usually comes out. Any ideas on how to fix the problem? Is there a switch that needs to be replace.
Dec 31, 2007 at 3:28 AM
JEREMIAH
  • 217 POSTS
there's a key interlock solenoid that prevents you from removing the key if the vehicle is not in park. could be that.....usually under the shifter.you should here it click when you cycle the key on and off.
Jan 5, 2008 at 6:07 PM
SMILLER2113
My key is stuck in the ignition and it won't release no matter what I do. This has nothing to do with the positioning of the wheels, I've tried that already
Feb 6, 2019 at 6:51 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
I would try WD40 in the tumber first work the key around but it sounds like the key and tumbler has gone bad which is common here are diagrams and instructions on how to change it out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
GREGTHOS
Thanks for this post I had this problem had to get a new key and tumbler cost me $121.00. I love this site
CEVANS
  • 49 POSTS
My wife says she has to rotate the steering wheel to get the key out sometimes. Why dies this happen?
Feb 6, 2019 at 6:52 AM (Merged)
  • 31,937 POSTS
The barrel and key assembly may be a t sticky, ensure that the key is not bent a little and you can try squirting a little powered graphyte into the lock, this is better than spray lube as the spray lube can attract dirt and gum up again, you can get the graphyte at hard wear and locksmiths it is quite cheap.
CZY4HEELS
  • 7 POSTS
I drive a 1990 Honda Accord automatic with about 145,000 miles on it. When the weather gets real cold (below freezing) the key gets stuck in the ignition after I turn the car off. I can take it out once the car recognizes that it is in park. The cooler is gets, the longer it takes for the car to recognize it is in park, and the longer it takes to get the key out. What is wrong? And what can I do?
BRUCE HUNT
  • 3,754 POSTS
I would say that the locking mechanism on the steering column needs to be lubricated. It appears to drag with the cold weather.
CZY4HEELS
  • 7 POSTS
That may help and I will try that, but why does it take so long for the car to realize that it is in park?
BRUCE HUNT
  • 3,754 POSTS
I think it reconizes it is in park but the colder it gets the stickier the release gets. The signal to let the key go is there just as fast on a warm day as on a cold day.
CHARLES SANTOS
my key broke and half of the key is stuck in the key ignition what should i do?
WRENCHTECH
  • 20,761 POSTS
You're probably going to have to get a locksmith involved. I believe these are programmed keys for the security system.
PHONEMAN63
I have a 2004 Accord LX with the key not removing from the ignition. The only way it comes out is when I disconnect the battery. Any ideas?
TY,
Alex
Dec 10, 2022 at 11:12 PM
  • 55,224 POSTS
Yep, the ignition lock needs to be replaced, I would get a new one from the dealer so they can program it for you before installation. have your VIN number ready. Here is what it looks like, so you get the right part. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Dec 11, 2022 at 3:30 AM
