2004 Honda Accord gear stick
2004 HONDA ACCORD
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
MUGD
gear stick wont move to reverse or drive or anyother position from park.i have to press that small switch that is located right next to it.it just suddenly happened.
Jul 25, 2010 at 12:17 AM
EDWARD.S
  • 166 POSTS
Hi, Check Your Brake Lights First. Verify That They Are working.If So, Then The Shift solenoid Is Bad .Some Of Them Are Located At The Shifter , And Some are Near the Ignition switch.
Hope This Helps You,
Good Luck
Edward S.
Jul 25, 2010 at 12:30 AM
