2004 Honda Accord Fuses
65,000 MILES • 4 CYL • FWD • AUTOMATIC
MARIO8002
When my wife got out of work her car would not start, she asked the security guard for help and he decided to use his golf cart to jump start it. (Why I dont know.) My wife said that she heard a weird noise when she tried to turn on the car with the jumper cables connected. None of the lights on the dash or the radio work. I checked all fuses inside the car and there was plenty of them burnt out. I have replaced some 20amp fuses but when I go to replace the back up fuse and radio fuse they blow again. What could have happened and how can this be fixed. Thanks.
May 21, 2008 at 8:54 AM
KHLOW2008
  • 41,812 POSTS
If the fuses gets blown again when you try to crank the engine, then most probably the main earthing cable continuity is broken. Check all earthings to see if they are ok.
May 24, 2008 at 4:54 AM
