Engine oil and filter replacement - what kind of oil?
64,000 MILES • 4 CYL • FWD • AUTOMATIC
OSSAI01
After changing my engine oil and the oil filter, I noticed that the engine sound changed a little bit. The recommended engine oil is 5W-20 but it was changed with 20W-50. But when I noticed the change in sound, I had to remove the oil and change it to 0W-40 as I couldn't get the recommended 5w-20. But the noise is still there, as if the engine is dragging, and there is a return noise any time the engine is accelerated. Could it be that the filter is inferior?
Jul 19, 2009 at 6:49 AM
F4I_GUY
  • 3,302 POSTS
Doubt the filter is faulty. If the engine was ticking, then I'd suspect a faulty filter. Here is a guide that will walk you through the steps of changing the oil correctly with the oil type and capacity below.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Fluid Types
New standard for engine oil, GF-4. See TSB SN050109 for Honda Service News 050109 for additional information.
Engine Oil
API Classification .................... Make sure the label says "For Gasoline Engines".
SAE Viscosity .................... 5W-20
Capacities
Engine Oil
Engine overhaul .................... 5.0L (5.3 Qt)
Oil change, including filter .................... 4.3L (4.5 Qt)
Oil change, without filter .................... 4.0L (4.2 Qt)
Most likely the pitch of the engine has changed because you are doubling the weight of the oil that is recommended by honda.
Jul 20, 2009 at 11:51 AM
SAM_USNC
how many quarts of oil and type of oil are required for this car?
Aug 15, 2019 at 10:36 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Fluid Types Engine Oil New standard for engine oil, GF-4. See TSB SN050109 for Honda Service News 050109 for additional information. API Classification .................... SG 1993-95 Del Sol 1.6L VTEC & 1993-96 Prelude 2.2L VTEC Above -2°F (-20°C) .................... 10W-30 (preferred) Below 32°F (0°C) .................... 5W-30 All Others Above 20°F (-7°C) .................... 10W-30 All temperatures .................... 5W-30 (preferred) Capacities
https://images.2carpros.com/forum/automotive_pictures/55316_96accordoil_1.jpg
HONDAACCORD99
I changed oil on EZLube and next day I found out, that my car was overfilled with engine oil (4 inches above mark on oil dipstick). Next day (after I allredy did drive about 30 mi) EZLube removed excessive oil. Now my car has strange noise and vibration and over heated. It gone allready1,5 month and feel my car getting worse. Now, when checking oil dipstick, there oil allover high. And it seems oil in coolant . I don't see any signs of coolant in oil. What signs of coolant in oil and oil in coolant? What damages can be done to my car? What signs of damages? How to solve it? What need to do?
Aug 15, 2019 at 10:37 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi hondaaccord99,
Coolant in oil or oil in coolant both denotes similar problems.
Thee is a leak between the system and the overheating most probably damaged the cylinder head gasket causing the leak. You would have to get the head pressure tested and head gasket replaced to resolve the problem.
DANRAMZI
Greetings,
I have Honda Accord 1999 4 cyl EX four doors
It has 142000 right now
I want to know what is recommended motor oil I have to use
My Auto technician recommend me to use 10w40 because of the high mileage so is that correct?
if it is correct what is the best motor brand oil ? and is the brand affect in my car which has 142k m on it ??
Respectfully
Dan
KHLOW2008
  • 41,812 POSTS
Hi Dan,
The recommended oil is 10W30 and I would stick with that if there are no oil consumption issues.
Each and every oil company claims their oil to be the best so there is no preferred brand. Just get those that are branded and it should be ok.
CANOELNENE
I combined 2 diffrent type of oils to my car. My car is a shift stick car. I combined 10w40 with 10w30 was that a bad idea? I did so because my car has a small oil leak and my car needed oil and thats all I had left. What do you guys think
Aug 15, 2019 at 10:38 AM (Merged)
  • 110,246 POSTS
It SHOULDN'T hurt anything, but the question is, what weight oil is in the vehicle now. You should try to avoid mixing different weights. What I would suggest is to change the oil and filter and get the correct weight oil in it. If the leak is small and you believe it is a gasket or seal, they make products that can help stop the leak. See your local parts store and ask what they have.
HONDATECH1983
  • 109 POSTS
It won't hurt anything, especially with the miles that are on your vehicle. When engine components are worn such as piston rings one option to help slow down oil consumption is to use a heavier weight oil as it doesn't pass the rings as easily. I wouldn't put any sort of additive in my engine to stop a leak, I would fix the leak. Start with the upper most leaks (vc gasket, distributor o-ring, vtec gaskets, etc...) then clean the engine up. Run it for a while to re-check oil leaks and see if any return.
KACEDON8
i recently bought a used honda accord v6 3.0ltr engine and dont know what type of recommended oil to use.i serviced it with mobil xhp and anytime i go on long distances the oil light comes on but its still within limits, i think i am using the wrong oil so please what oil is d recommended oil to use
many thanks
KHLOW2008
  • 41,812 POSTS
Hi kacedon8,
It is not the brand of oil that matters. The specifications is the most important and the recommended specification is SAE 5W-20.
If the oil level is low, high speed driving might cause the oil lamp to flicker.
