2004 Honda Accord diagnostic codes
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
BELLAG
Diagnostic codes appear for car P2254 and PO154 what is this and will it hurt to drive with this on
Sep 4, 2009 at 8:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P2254 - Front A/F Sensor (Bank 2, Sensor 1) VS Line High Voltage
DTC P0154 - Front A/F Sensor (Bank 2, Sensor 1) Heater System Malfunction
These codes refer to your vehicle's emission system, driving in this condition may cause poor fuel mileage..other than that no harm will be done to vehicle.
Sep 4, 2009 at 10:52 AM
HARLEY B SERRANO
My 2004 honda accord oil light and battery light is on. It turned it on it turned off. I turned back on and put my foot on the brake and switched back to the gas pedal quick just so I can drive it home. Car doesn't really want to turn on. And the belt turns really slowly. What can be the problem?
OB11 scanner the codes: M, F, CC, C, EV, O, OH, E pop up
No check engine is on.
Dec 19, 2019 at 2:31 PM
This sounds like we have a number of different issues. The oil light is due to lower oil pressure and the battery light is due to lower battery voltage. They are not necessarily related. The codes that you got are all for the HVAC system so again, not related to the other issues.
I would suggest with starting with the oil pressure light as that is the most crucial. We need to hook up an oil pressure gauge and see what the actual pressure is. If it is low then we need to suspect the oil pump or possible larger engine issues. If it is not then there is a sensor issue. Not as crucial but still something you need to address. After that, you will need to have the battery and alternator tested to find out why you have low voltage.
Dec 19, 2019 at 8:56 PM
