2004 Honda Accord code po341
RUCKER66
Engine Performance problem
2004 Honda Accord 4 cyl Front Wheel Drive Automatic
replaced both cam sensors code returns car runs well input 12 volts good ground 5 volts output wire disconnected key on 2.4 vtech motor
Oct 6, 2010 at 9:56 AM
HONDA TECH 1818
  • 536 POSTS
A stretched cam chain, resulting from infrequent oil changes, can cause the MIL to come on
with DTC P0341. Old oil causes the cam chain
to wear quickly. You can check for a damaged or stretched cam chain by measuring the cam chain autotensioner rod length. If it’s more than 13.5 mm, you’ve got a bad cam chain and will need to replace it
along with the cam chain auto-tensioner.
Oct 6, 2010 at 6:13 PM
