2004 Honda Accord alternator or battery??
KRAIG205
Electrical problem
2004 Honda Accord Front Wheel Drive Automatic 141000 miles
the accord has a battery idiot light. it has come on intermittently, been checked but cannot find out why. yesterday it came on and later in the day the car would not start. we were able to jump it started but the lights remained dim and revving the engine did not change anything. I thought if you revved the engine, the lights would get brighter. but they did not and battery died again. that leads me to believe the alternator is not providing electricity to the components and charging the battery.
Jan 19, 2010 at 12:09 AM
KHLOW2008
  • 41,812 POSTS
Hi kraig205,
Thank you for the donation.
The alternator or its wiring circuit has failed and is not charging the battery. If you have a DVOM you can test the charging rate by attaching the DVOM to the battery terminals abnd running the engine.
The voltage should be between 13.5 to 14.5 ans if it is battery voltage, it is not charging.
Aug 24, 2020 at 7:30 AM
