2004 Honda Accord 60,000 miles inspection
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
RYPAL0613
my car is due for 60,000 inspection at the honda dealership. is this really necessary? beacues it's gonna cost $400 for getting this inspection
May 7, 2009 at 5:33 PM
MMPRINCE4000
  • 8,548 POSTS
It is really your choice, but these inspections can find small problems before they turn into big ones.
Check your owners manual, if it a matter of changing oil, inspect this, inspect that, then you could probably do it yourself.
If on the other hand the valve lash must be adjusted, that is probably best left to the professional mechanic, unless you are an experienced one.
May 8, 2009 at 12:15 AM
RYPAL0613
thanks for answering my question. i got one more question. i called the dealership today about the 60,000 secvice check he said they going to flush everything, the ATF,coolant,etc. for $400. do you think that's reasonable price and do you have any suggestion? thanks
May 8, 2009 at 1:15 PM
MMPRINCE4000
  • 8,548 POSTS
Yes, I would consider that reasonable. Coolant must be captured, as it is highly toxic. Changing the ATF is excellent insurance against any trans. problems.
Changing oil, ATF, and coolant are the three best maint. items you can do.
Have them inspect for any leaks, check brake pads, CV boots, belts and hoses.
Preventative maint. is the best insurance against very expensive repairs.
May 8, 2009 at 10:59 PM
RYPAL0613
i really appreciate your help. i hope their's more people like. keep up the good work. God bless you
May 9, 2009 at 5:55 AM
MMPRINCE4000
  • 8,548 POSTS
Thanks, and thanks for using 2carpros.
May 10, 2009 at 12:27 AM
