2003 Honda Accord Whats wrong with it?
93,000 MILES • 4 CYL • 4WD • AUTOMATIC
NANA250
Ok so my car is shaking wobbling and shuts off when its on but standing still. It will only turn on if we hit the gas pedal. The check engine light is on. We've had problems where the car is going through oil a lot. The mechanic said it was the pistons, but as long as we kept putting oil in it it would hold out. We also put fuel injection fluid but that didn't help. Is there anything i I can do or is it just a clunker now?
Sep 28, 2009 at 6:51 AM
MATHIASO
  • 1,209 POSTS
The valve guides could be the source oil consumption because of the mileage of your car ( 93000)
Oil leakage past the valve guides seals is a more likely cause of oil consumption than leakage past the piston rings
ok, let's verify this by removing the spark plugs.
When only one side of a spark plug is fouled with carbon , leaking guide seals are indicated.The carbon will be on the side of the spark plug that was facing the intake valve.
I do not know if your honda accord is a DX,LX,or EX, so I can go more in datail helping with the valve guides.
Sep 28, 2009 at 9:45 AM
SAMBAL BADJAK
  • 20 POSTS
[quote:ffd0c69908="Nana250"]Shakes or Wobbles problem
2003 Honda Accord 4 cyl Four Wheel Drive Automatic 93000 miles
Ok so my car is shaking wobbling and shuts off when its on but standing still. It will only turn on if we hit the gas pedal. The check engine light is on. We've had problems where the car is going through oil a lot. The mechanic said it was the pistons, but as long as we kept putting oil in it it would hold out. We also put fuel injection fluid but that didn't help. Is there anything i I can do or is it just a clunker now?[/quote:ffd0c69908]
Have you had the car scanned? If so, what is the trouble code?
Sep 29, 2009 at 5:12 AM
